losing fuel pressure
Old Oct 19, 2008 | 10:42 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
Well the title says it i am losing fuel pressure. i will be driving on the freeway for an hour to a hour and half then my fuel pressure will start dropping. It will start to get down into about 30psi and if you dont keep the revs up it will start dropping until the car will eventually lose all pressure. i will wait a 1/2 hour then it will run for a little bit maybe 20 to 25 minutes. i just installed a new holley 255lph fuel pump and new fuel filter before this started happening. i checked the volts on the battery the alternator and the fuel pump it all seems to be good. i am really confused. my car is going to the transmission shop right now to fix a problem, it isnt shifting till 6000rpms in every gear, but that is a different issue. any ideas??? maybe fuel relay??
Old Oct 20, 2008 | 02:58 PM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: losing fuel pressure
Sounds like vapor lock. Since it started when you replaced the pump, there may be air getting in on one of the connections. It is a PITA to trace down.
Old Oct 20, 2008 | 03:11 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
I don't see how that's possible unless there is a leak in the tank before the pump making it suck air. Otherwise everything is pressurized and would leak fuel. I would suspect the new pump or the regulator. You could squeeze the return line when the pressure starts to drop. If it comes back up, it's the regulator. Did you replace the short suction line in the tank and with the right hose?
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
