Motor Mounts ???
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Motor Mounts ???
well i am going to try to change motor & tranny mounts tomorrow . i have a lift and tools , just asking for any helpful ideas/hints . tranny mount is a no brainer . the motor mounts are where i could use some advice/help . any suggestions or advice ??? yes i did a search , they were not specific to the mount its self with eng. installed .
Transmission: 4L80E/4L80E
Obviously, you'll have to lift the engine off of the frame half of the mount after removing the bolt that goes through both the engine and frame halves.
Then the fun begins. The frame side is held by three bolts with nuts inside the crossmember. Getting to those nuts is a pain.
I assume you got new mount inserts. After you get the mount off of the frame, follow the instructions for replacing the inserts.
ambainb
Apr 25, 2016 09:21 PM
NBrehm
Aug 5, 2015 07:57 PM
