GETTING RID OF EGR SYSTEM!
Old Oct 20, 2008 | 07:40 PM
Dean_GTA's Avatar
Car: 1988 TA GTA
Engine: L98 Replaced w/ 350/330HP W/TPI
Transmission: Stock 700r4
Axle/Gears: stock 3:27
What are the advantages and disadvantages of getting rid of your EGR System on a TPI Motor? What is the process? I have a TPI setup on a 350 with Vortec heads.
Old Oct 20, 2008 | 11:13 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
Re: GETTING RID OF EGR SYSTEM!
advantages : 1 pound? weight reduction, little bit cleaner intake tract
disadvantages: higher combustion chamber temps, slight gas mileage decrease, ecu needs to be tuned to run without it.
topic has been covered, do a search, lots of info on it, basically what it boils down to is there is no reason to remove it, if you have one, leave it.
Old Oct 21, 2008 | 02:11 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Not to mention lots of NoX pollution for no reason. The EGR doesn't hurt performance.
Kenwood
Sep 11, 2015 12:50 PM
Nick McCardle
Sep 10, 2015 08:36 PM
SG91camaro
Sep 5, 2015 10:27 PM
rjcme
Sep 5, 2015 01:23 PM
