No Spark 87 2.8
Old Oct 21, 2008 | 02:03 PM
Mikei16's Avatar
Car: 1987 camaro & 55 chevy
Engine: 2.8 and a 406SBC
Axle/Gears: 355 in the 55
No Spark 87 2.8
I have a 87 2.8 Vin S, I don't have any spark, here is want I’ve replace, the dist, the dist module, pickup coil, cap, rotor, coolant sensor, TPS and replace the pickup coil again, it was bad, I thought I had it repaired with the new pickup coil, but, still no spark. I replace the ign coil as well. Thanks for any help.
I have power going to the ign coil and the wires going from the coil to the module (2 wire harness) are both hot? Rotor is turning. The times before I got it to run, it would run and all of a sudden it would turn off like someone turn the key off. I read somewhere that when you turn the key on, it sends power to the ign module as well as the coil? At this point I am thinking ign switch or the ECM?? Any Help would be great.
Mike I
Old Oct 22, 2008 | 08:59 AM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
Re: No Spark 87 2.8
Any trouble codes? Be sure that your check engine light operates correctly. It should turn on when you first turn the key on. If it does not then It may be your ECM. If you have codes I would start troubleshooting the parts referenced by the code(s). I doubt that it would be your ignition switch since you have power at the coil. Check the ignition module in the distributor. You may be able to take it to a local auto parts store. Some of them have a way to test these. This may sound obvious.... Double-check your plug wires. It is possible to accidentally swap the coil wire with one of the others.
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
