power steering bracket question
Old Oct 23, 2008 | 11:30 AM
TransAm_85's Avatar
Car: 1985 Trans Am
Engine: built 355
Transmission: th350
Axle/Gears: Borg warner 3.08's
Im buying a 350 out of a 93 van. I cant use the power steering pump because it has a different reservoir its connected to a hose that runs up and bolts under the hood. My question is can i put a truck pump on the van bracket or do i have to get the bracket out of a truck? Do all sbc power steering pump have the same bolt pattern?
Old Oct 23, 2008 | 12:13 PM
TransAm_85's Avatar
Car: 1985 Trans Am
Engine: built 355
Transmission: th350
Re: power steering bracket question
anybody??????
Old Oct 23, 2008 | 06:09 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Patience, Grasshopper. We can't all be on line when you are. . .
The simplest solution would be to use your stock accessories, assuming you currently have a V8. If you want to use the truck steering pump, just mount the reservoir somewhere. I believe, though, without being able to confirm it with my own equipment, that the pumps use the same mount bolt pattern (my '95 diesel truck has the built-in reservoir).
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Mar 22, 2019 09:39 PM
colton_carlson
Mar 8, 2019 12:21 PM
redmaroz
Aug 16, 2015 11:40 PM
