new bearings... very tight!
Old Oct 24, 2008 | 09:31 AM
Jammin'Trey's Avatar
Ok I put new large journel rod bearings in. -.010 size, crank measures 2.0870. it was turned a while back. Crank is in great shape, I just wondered how hard it should be to turn over? Before I could turn motor over fairly easisly with the v-belt pully mod I use a braker bar and its tough. Doesnt bind just has a very snug fit. Very smooth but snug I sed tons of oil when putting the new bearings in so they are VERY well lubricated..... Just curious what weight oil I should run with a .003 gap, and how I should break them in.
Old Oct 24, 2008 | 02:09 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: new bearings... very tight!
you don't really break in bearings. Just drive it fairly easy until the oil is up to temp, then go hard.
10W-30 oil is fine.
what's your endplay?
Old Oct 24, 2008 | 04:14 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What are you trying to turn over? Only the crank? Crank and pistons? Crank, pistons and cam with the heads on and plugs in?
Old Oct 24, 2008 | 10:41 PM
crank piston and heads with valves adjusted, no plugs in. Its really not that hard to turn over my buddy tells me.
Old Oct 26, 2008 | 08:12 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
I would pull the oil pan and plastigage every bearing. It isn't impossible that one of the journals were turned incorrectly. ESPECIALLY if the crank was the only thing pulled (ie: rings are not new).
Also, was the crank pulled because of bearing failure?
If so it could hane an out-of-round rod end.
Ed1LE
Sep 30, 2018 09:14 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
camarohelp
Sep 22, 2015 03:19 PM
HikoriYami
Sep 21, 2015 07:11 PM
brockerboy
Wheels and Tires
Sep 17, 2015 03:59 PM
