84 trans am with horrible gas mileage
Old Oct 25, 2008 | 10:34 PM
84transam87's Avatar
bought this car about a month ago. it had been sitting for 4 years. guy i bought it from said he emptied gas and put new gas in. after i got it i changed spark plugs/ wires, cap/rotor, coil and new air filter. ran a bottle of sea foam through the gas as well as changed the oil. i have now gone through 2 tanks of gas the first i got about 160 miles out of it and this time i got about 170/175 miles on a 13.22 gallon fill up. so im getting about 13/14 mpg. only things i have not changed is the fuel filter being that i cant get the damn line off and the oxygen sensor. on cold starts the car can idle low and at other times idle at about 1500 rpm until i hit the gas. only other thing i can think of is that it has an exhaust leak around the cat. once the car warms up it drives what seems like just fine. im not even sure what this car can even get for mileage so if im getting horrble gas mileage and you have suggestions on what may be the issue please let me know. thanks
Old Oct 25, 2008 | 10:44 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: 84 trans am with horrible gas mileage
Has the carb been rebuilt? I was getting around the same MPG with my '84 T/A before the carb was freshed up but after a rebuild kit and throttle shaft bushings it jumped to 20-24 MPG.
Old Oct 25, 2008 | 11:21 PM
20-24 sounds a whole lot better. just might have to do that. any idea how to get a stingy gas line disconnected??? i have sprayed it and used vice grips and all
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
InfinityShade
Aug 22, 2015 08:00 PM
