stuck on defrost
Old Oct 26, 2008 | 11:27 AM
larryjoe's Avatar
Car: 88 formula
Engine: 350 tpi
Transmission: 700
Axle/Gears: 3:23
stuck on defrost
my a/c is stuck on defrost and not putting out very much air at all, my question is has anyone had this problem? I know that there is a flipper in there soemwhere that switches it over, I'd just like a head up on whre it is and what else could be the problem, thanks.
Old Oct 26, 2008 | 11:35 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: stuck on defrost
defrost is the default, most likely you have a vaccum leak. Check the supply line in the engine compartment and make sure its connected, check to make sure the vaccum connector on the back of the control head hasn't come loose.. I knocked mine off before when I swapped out the radio..
Old Oct 26, 2008 | 01:08 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The problem is common. A search will provide a ton of info.
JamesC
tmellott89
Oct 14, 2015 02:06 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
whibbs
Exterior Parts for Sale
Sep 28, 2015 07:53 PM
ctoledo0834
Sep 18, 2015 04:16 PM
scottmoyer
Sep 7, 2015 07:06 PM
