Will MSD Ignition System make difference?
Old Oct 26, 2008 | 07:15 PM
fearthisinc's Avatar
I was thinking of upgrading the ignition system of my 87 Iroc w/ 350 TPI. I was looking on summit and came up with a system that looks fairly easy to install and is plug and play. What do you guys think of this setup? Is it worthe it?
MSD Ignition control - Either MSD 6AL Model 6420 or the MSD 6 Digital Plus
MSD Cap and Rotor Kit
MSD Wires 8mm
MSD Wire Harness
MSD Coil 8226
Old Oct 26, 2008 | 07:24 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Will MSD Ignition System make difference?
You don't need the ignition control.
Old Oct 26, 2008 | 07:32 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
It was worth 2 tenths in the 1/4 when I did it. I was running something in the upper 11's at the time.
Old Oct 26, 2008 | 08:45 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There's a big difference between putting it on an 11 second car and a 15 second car.
Old Oct 26, 2008 | 08:58 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
That's why I included that the car was already running high 11's, as it didn't really seem to do much when I put the old 305 back in at the end of last year.
Old Oct 27, 2008 | 12:18 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
On Allen's '89 GTA, on his previous engine, the MSD 6A and coil made a 2 horsepower difference over the stock coil and ignition. That was at 330 RWHP running high 12's.
We dynoed it with the MSD, then changed back to stock and dynoed again. It lost 2 horsepower. Then we put the MSD back on, and it gained the 2 horsepower back.
Old Oct 28, 2008 | 09:00 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
im considering msd too, 2questions. does msd bypass your ignition module? how reliable is it, i heard it could leave u stranded beside the road?
Old Oct 28, 2008 | 09:23 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
The MSD box will become your new ignition module. I can't say much for the MSD unit, but I think there are better ones out there. I run the crane cams version of the msd, and it has been great for bout 3 years running. Actually my ignition box, coil and wires are crane cams. I know Summit has their own box out too in the last year or so that might even have more features/functionality than the msd and crane cams box.
Old Oct 28, 2008 | 09:27 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you're keeping computer control, the MSD works in conjunction with your ignition module. It can't really keep you stranded since you can easily switch back if you need to.
Old Oct 29, 2008 | 02:30 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
A waste of money and a compromise in durability for near stock and mild street. I only run it for the stronger spark and ignition retard capability when I'm running nitrous. For naturally aspirated operation, I revert to stock ignition to save wear on the other ignition components and for better reliability. None of those brands of boxes are as reliable as your stock system.
Old Oct 29, 2008 | 02:51 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
Actually i just installed a 6A box last night on my 91 rs with a 350 tpi nothing facny just headers and exhaust, i was actually surprised seeing how everyine told me dont bother on a stock car as soon as i cut the car one i had a better throttle response, i already had an msd cap and rotor as well as wires and well the box was free since i had it sitting from one of me previous projects, doubt it will make my car any faster but for free and a 30 min install not bad(plus it looks cool pointing out a red box to the gf for bragging lol) n
BRoss99
Aug 10, 2025 05:08 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
TheExaminer
Aug 26, 2015 04:59 PM
