Help with p/s pump bracket 87 Firebird
Old Oct 26, 2008 | 10:45 PM
Silver87's Avatar
Car: 87 T/A
Engine: 305 4BBL
Transmission: 700R
I noticed the other day a vibration in my engine. At the same time I noticed a belt squeal in the mornings. It would go away and not come back until the next morning. I checked the belts and pulleys and found the p/s pump pulley bracket has a crack in it starting next to a little notch on the left side of the bracket and a slotted area. If I pull on the belt I can see it move a little. How do I get the bracket and pump off? What do you pry against to tighten the belt when putting it back on? Do I tighten the A/C belt that also goes around this pulley or the p/s belt first? Thanks.
Old Oct 27, 2008 | 12:40 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Tighten the PS belt first.
There are bolts & nuts on both the front and back of the pump. A bit of a pain, but works when properly tightened.
Old Oct 27, 2008 | 12:41 AM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Re: Help with p/s pump bracket 87 Firebird
To get the bracket off, you may need to remove the pulley from the front of the pump. You would have to tighten the P/S pulley first, then the A/C compressor. The P/S has 2 belts and the A/C compressor has 1. Don't want to mess with removing the pulley, I have a P/S pump with brackets sitting here. Willing to sell for $15 + Shipping. Worked fine when pulled. I switched to serpentine belt system and my brackets came with pump already attached. PM me if interested.
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
toronto formula
Nov 10, 2015 06:17 AM
mcquigg
Aug 13, 2015 02:26 PM
