Rotating assembly to tight?
Old Oct 27, 2008 | 10:21 AM
310IROCZ's Avatar
Hey guys, I just reassembled my short block 350 with new hypernutectic pistons, rings reconditioned rods and crank. I ground the top rings down per the instructions but now that it is assembled (heads not on yet) I can bearly rotate it by hand, if i use a ratchet it turns fairly easy but i cant help but think it is not a free as it should be. It does not bind up or anything like that it just feels like the pistons are very tight in the bore. any advice?
Old Oct 27, 2008 | 11:12 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Rotating assembly to tight?
all 8 pistons in? I could barely rotate mine over. You're rubbing 8 rings against snug bores, that's tough.
if the bores were honed per the pistons, you're fine. You can check the piston fit with a feeler gauge at the skirt area from the bottom if you want. Should be around 1-2 thou I believe.
Old Oct 27, 2008 | 11:49 AM
310IROCZ's Avatar
Cool thanks, all 8 are in tourqed mains and rods. I checked the skirt it is 2 thous. so i know the pistons are ok and i ground the top ring is it possible that the 2nd ring needs to be ground? just want to make sure be sure befor i put it all back toghther.
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
gord327
Oct 3, 2015 01:25 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Dragonsys
Sep 25, 2015 03:51 PM
