power loss
Old Oct 28, 2008 | 11:04 AM
woody's89's Avatar
power loss
Hope somone here can help an old guy. My '89 RS loses power when slightly accelerating on a slight incline (just before kickdown) and especially with a/c on. Starts and runs perfect otherwise, until engine light comes on. Occurances became more and more frequent until I changed knock sensor, which I thought had remedied this condition for a while, but still occured about 4 times in a 120 mi. round trip. When light comes on, instantly I lose power as if pulling a heavily loaded trailer. I can turn engine off and restarts immediately, and runs fine until nxt occurance. Thanks in advance for any enlightenment. Art
Old Oct 28, 2008 | 11:16 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: power loss
You need to read the code to see what the error is. It's in the FAQ's. Without the code we'd just be guessing.
Old Oct 28, 2008 | 11:33 AM
woody's89's Avatar
Re: power loss
Thanks for the quick reply. Would it do any good to try to read the code when the engine light is not on? The malfunction is much less frequent since the knock sensor replacement, but agravating nun-the-less on a very well kept 98.00 mi. car. Art
Old Oct 28, 2008 | 11:37 AM
jv9999's Avatar
Engine: 5.7L/350
Re: power loss
The codes are stored for some number of start cycles even after the light goes out.
Old Oct 28, 2008 | 11:44 AM
Daves03's Avatar
Car: 1991 Chevrolet Camaro RS Red
Engine: 305 V8 TBI
Transmission: TH-700R4
Re: power loss
i would clear out the codes before you retrieve the codes to eliminate all the old codes and get the newest code, clear em and drive it to make the light come on and then retrieve your code.
Old Oct 28, 2008 | 11:49 AM
woody's89's Avatar
Re: power loss
Thanks again, I'll try that.
theshackle
Sep 17, 2020 08:26 AM
formula_novice
Sep 5, 2015 03:58 AM
Warlocksirix
Aug 29, 2015 11:36 AM
sailtexas186548
Aug 24, 2015 10:11 PM
Bradsaundry
Aug 12, 2015 12:34 AM
