help with car idling 3000 rpms
Old Oct 31, 2008 | 08:21 PM
rock861261's Avatar
my car ran fine then i installed a new manifold and reset the timing on the balancer to the big triangle on the balancer i then set the rotor to the first plug position started right up however it now reves at 3k check engine light just blinks code 12 constantly ( i know its suppose to blink 3 times) any ideas maybe timing? i havent been able to time it yet
have also checked for vacuum leaks none found
and its a 91 camaro 350
Last edited by rock861261; Oct 31, 2008 at 08:49 PM. Reason: Automerged Doublepost
Old Nov 1, 2008 | 11:06 AM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Re: help with car idling 3000 rpms
yea i think you can ruel out vac. leak b/c its going to need fuel to rev and hold 3k.
tpi or throttle body?
Old Nov 1, 2008 | 11:07 AM
rock861261's Avatar
tpi speed density
Old Nov 1, 2008 | 02:01 PM
rock861261's Avatar
think its that i didnt unclip the timing wire when i reset the timing?
Old Nov 1, 2008 | 05:57 PM
rock861261's Avatar
i now unclipped the wire and the tps set the timing it sounds good as no timing light 750 rpm connect the clip is ok idles great when i connect the tps it dies and will revv back up to 3000 when restarted im tps worked great reight before the swap any ideas guys
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
killer777
Aug 8, 2015 02:47 PM
