Smog Control?
Old Nov 1, 2008 | 04:16 PM
TBIfreak's Avatar
Car: 1992 Camaro RS
Engine: Crate 350 W/TBI
Smog Control?
What effects would there be If I removed the smog control from my 92 Camaro RS, I'm pretty sure mpg would drop, but would it hender engine performance?
Old Nov 1, 2008 | 05:29 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Smog Control?
a lot depends on where you and car live . if you have inspections you may need to keep it . if not go ahead . if anything mileage will get better . just take 1 step at a time , let ECM adjust a day or 2 . then do the next step . i started with smog pump , then cat gut , 3" catback , then headers , and air filter induction . ended up with 27-29+ m.p.g. hwy . performance will be better . worked for me . good luck .
Old Nov 2, 2008 | 11:15 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Smog Control?
First, This is a common topic and you'll find your answers there.
Second, remember its illegal to remove, disable, or tamper with smog devices on a street vehicle in all 50 United States (and I think Canada too) regardless of whether your state does emissions checks or not.
I just passed CA's smog test in my highly modified car. I kept everything hooked up and I still make this much power. It can be done.
Old Nov 2, 2008 | 11:35 AM
TBIfreak's Avatar
Car: 1992 Camaro RS
Re: Smog Control?
Thats Kinda what I was wanting to know, thanks big time.
Old Nov 2, 2008 | 12:02 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: Smog Control?
Air pump isent to blame for the LO3's 170hp, you would gain more hp by changing the stock air filter every month then by removing the air pump.
The complete stock exhaust sistem that came with the LO3 is wery restrictive and should be upgraded. A highflow 3" cat will not hurt performance and fuel economy at all.
Full exhaust will give your LO3 around 15-20hp and better fuel economy.
Removing EGR gives less MPG and does not affect performance at any noticebly level.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
racereese
Oct 10, 2015 09:39 PM
budowski
Carburetors
Oct 2, 2015 10:16 AM
reactor60
Sep 22, 2015 01:44 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
