#8 not hitting?
Old Nov 2, 2008 | 07:36 PM
tibbitt23451's Avatar
Car: 1991 Camaro RS
Engine: 406
Transmission: t5
Axle/Gears: 373
#8 not hitting?
i have the timing set a 10 btdc, new wires ,new cap,new coil & spark plug. if i pull the #8 wire off of the dizzy theres no change in the idle? it idles a little rough and i don't think #8 it hitting. i did a compression check it's 145 psi, also readjusted both valves. it's a 1983 z28 with a 355 and 882 heads with stock cam. what should i check next?
Old Nov 3, 2008 | 12:16 PM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
Re: #8 not hitting?
Are you getting spark to the #8 plug? Might just need a simple tune-up. Cap, rotor, wires, and plugs. When you pulled the plug out to do the compression check what did it look like?
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
apie2546
Oct 16, 2016 02:24 PM
RS Reaper
Sep 27, 2015 07:04 PM
Twinn Engines
Sep 25, 2015 06:27 AM
