Thrust bearing not sitting flat!?!
Old Nov 2, 2008 | 12:56 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
On my last main I have noticed that the bearing actually protrudes from the cap ever so slightly. It seems to sit fine in the block itself but hangs out enough to catch more than a nail on the cap side.
This is even after torquing down then mains with the crank installed. Even so, the clearance seems to be equal to the other mains.
Is this something that needs to be addressed? The block was line honed for this build.
Old Nov 2, 2008 | 03:27 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Thrust bearing not sitting flat!?!
Did you seat the bearing properly with a mallet?
Old Nov 2, 2008 | 03:33 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
As long as the clearance plastigages out correctly you should be fine. Sometimes the parting line is not exactly in the center of the crank center line. This means more of the circle is in either the block or the cap. This is why it is so important to keep the caps matched to their original postition in the block. When the block (with caps installed) is bored for the crank, the center of bore does not necessarily pass thru exactly on the parting line.
Old Nov 2, 2008 | 03:44 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Aperion...I did not seat the bearing. Where would I 'smack' it to do this correctly? I assumed torquing the caps down would true things up.
Supervisor...I did not know that and will keep that in mind. IIRC there was no issue with this before the line hone. I was possibly thinking he took too much off the caps when he performed the line hone. Also, the top half of the bearing (inside the actual block) seems to sit flush...
Old Nov 2, 2008 | 03:52 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
This is the #5 main bearing you're talking about, right?
Old Nov 2, 2008 | 04:56 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Correct.
Old Nov 2, 2008 | 05:10 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
With the caps seated and the bolts turned down but not torqued, give the crank a smack or two rearward and forward with a soft faced hammer, then torque it down.
Old Nov 3, 2008 | 12:06 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Will that somehow push the bearing in the cap further or is this just to make sure everything is lined up properly?
Thanks a ton for the help guys.
Old Nov 3, 2008 | 12:31 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, it'll just make sure everything's aligned. Like Supervisor42 says though, it's really not a problem if the bearing isn't perfectly flush in the block.
6speedIROC
16
Mar 15, 2023 08:33 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
sahlomonic
Sep 20, 2015 07:15 PM
corey8084
Sep 17, 2015 02:56 PM
Mr. Chevy
Sep 11, 2015 06:06 PM
