89 T/A starting problem
Old Nov 3, 2008 | 03:11 PM
gcbuie's Avatar
Car: 89 Firebird Trans-Am
Engine: 5.0 TPI
Transmission: THM 700 R4
Axle/Gears: 273 Limited Slip
350 TPI, 117,000 miles on engine.
Starts fine most of the time, but once in awhile you turn the key, & nothing!
I found that if I moved steering wheel up & down, it would start.
What do you think? Transmission neutral switch? Ign switch?
Help!
Old Nov 3, 2008 | 03:27 PM
1bad66ss's Avatar
Car: 66 Chevy II SS/89 iroc
Engine: 355/305
Transmission: 350 Turbo/T5
Axle/Gears: 3.08 posi
Re: 89 T/A starting problem
Just a wild guess, but it could be one of the two wires that go to your vat system maybe broke, they run through the column to the switch.
Old Nov 3, 2008 | 07:25 PM
sms gta's Avatar
Car: 1989 Trans Am GTA WS6
Engine: 350 TPI 5.7
could b. my 89gta went through 5 ign modules and would act the same way. another item was a bad battery. i thought my ecm was bad this last time and i had my ign mod fixed and thought great now #6 or my vats, cause i wiggled my igniton and started. turned out to b my starter noid when car got hot. its frustrating i know. i about had it til i got it sorta figured out and i had this car for 8yrs now.
Old Nov 4, 2008 | 02:39 PM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
Could be the ignition switch. This is mounted down about half way between the firewall and the steering wheel. It has a metal rod that comes from the tumbler that connects to it. Did that come loose somehow?
I would check your wires too. Maybe you have a broken wire or bad ground.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
92camaroJoe
Aug 13, 2015 06:07 AM
