Car Dies n wont start back up
The car will run for a while I can even drive it but just all of a sudden it dies. The fuel pump had been making alot of extra noise that can be heard from the tank and in the fuel lines under the hood. So I went ahead and dropped the tank and replaced the fuel pump. But still had same noise and also the car still dies. I have a 85 T/A that had tpi, I converted to a carb when i swapped motors but when i replaced the fuel pump I just put the stock one back in. No matter I dont understand why it just dies suddenly and wont start back up for quite a while. After about an hour or so I can go back out and start the car again let it run for about a minute and a half then it will die again. Please help me find out what i should be looking for. Thanks in advance for your help guys!
Re: Car Dies n wont start back up
might be the ignition module when it gets hot it stops working and when it cools down its good again. I had to replace mine. My car never stopped running but when I would shut it off and try to restart I would have to wait for it to cool down. I have an 88 tpi 5.7 -- might not be it but just an idea
Ill take a look but I converted from TPI to carb so i dont think the Ignition module has any effect on the motor anymore
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
When it is not able to run check for consistent spark on all wires. Also check fuel pressure. Maybe pull the plugs out and take a look at them.
My guess is that you are having an issue with the ignition so I would start there.
Transmission: 4L80E/4L80E
The ignition module is a component within the distributor. It will exist whether computer or no-computer unless you have a box like MSD that is wired directly into the pick-up coil.
From your symptoms, that's what it sounds like, either that and/or the coil. What kind of distributor are you using?
db057
Aug 11, 2015 10:11 PM
