1.6 rocker arms ???
Old Nov 7, 2008 | 09:39 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
1.6 rocker arms ???
well my new ( old ride ) has an un-molested lo-3 eng. . still has smog pump etc. . well my question is will the comp. cams 1.6 roller tip rockers work ? i have heard some stories about pushrod clearence problems . i had the 1.52 rockers on my other eng. , liked them . any feedback would be great on the clearence question . need to do valve seals etc. thought new rockers at the same time would be the way to go . i will not be removing heads . thanks in advance .
Old Nov 7, 2008 | 11:00 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Re: 1.6 rocker arms ???
you will be fine. I have had the same 1.6 rockers on my car for 3 years without issue. but if you want to replace the valve seals it wouldn't be a bad idea. but also if you do that you might as well replace the springs while you're at it.
Old Nov 8, 2008 | 10:29 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
, do the valvesprings. You don't need anything fance, a regular $20 set of stock replacements are fine for your cam and rpm range, even with the 1.6:1 rockers.
Old Nov 8, 2008 | 12:08 PM
boldguy's Avatar
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
Doing something like this would be like adding a new cam. performance wise depending on how well the heads flow.
A question to think about: Would there be an issue with valve cover clearance??? What about on an L98? (that second question is for me, sorry to rape the post .
Ed1LE
Sep 30, 2018 09:14 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
