Tq converter to flex plate bolts are tight--still making noise?
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I am wondering why my car is still making a loud metallic clacking like soud from the converter/flexplate region.
I raced at the track the one sunday, brought it home and didnt run the car again til like 3 days later and i have that noise at idle that you get when your flex plate to converter bolts become loose. its done this before and when i tightened them up, the noise went away
Now i've checked these bolts 3 times to be sure and they are snug! still get this sound
Did I break something in the trans/converter or crack the flex plate? I did spray the car off the line to a 1.41 and 1.45 60 foot time. But i didnt notice the noise when driving home that day. Its like after it cooled down, the bolts somewhere became loose?
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: Tq converter to flex plate bolts are tight--still making noise?
I would say check the flexplate for cracks. Also, check to see if the bolts are bottoming out against the torque converter, making seem like they are tight, but they're not. If not, I know this may be a far shot, but drop the trans pan, see if theres any metel in there, maybe the converter is starting to come apart.
Car: 89 Iroc-z
Transmission: TH400
didnt appear to be ovaled, but i'll have to check for flex plate cracks.
the tranny seems to be working ok when normally driving. I'll have to check it out tho it needs a flush. I'm probly gonna yank it all out over winter to refresh anyway
Car: 1983 G20 Chevy
Transmission: 4L60
Sounds very much like the flexplate is cracked. Check it out ASAP, it would not be good at all if it let go.
Car: 89 Iroc-z
Transmission: TH400
any recommendations for an SFI flexplate that can hold 600+ hp?
1992 Trans Am
May 10, 2023 07:19 PM
theshackle
Sep 17, 2020 08:26 AM
mhatfield 14
Oct 24, 2015 07:48 AM
