timing chain question
Old Nov 9, 2008 | 08:04 PM
leo037's Avatar
Car: 92 RS with B4C Package
Axle/Gears: 323
Installing a new chain in my 88 350 the bottom sprocket has 3 dots I know the center one is for regular install, if I were to use the advance of retard will my engine run bad or will I just need to reprogram my chip to match?
Reason is I am installing Trick Flow Twisted Wedge Heads and My valve is hitting the piston on the intake side with only .505 lift and I'm hoping this may help.
Old Nov 9, 2008 | 09:40 PM
TylerP's Avatar
Car: 89 T/A and 97 Formula (sunny days)
Engine: 305 TBI / LT1
Transmission: 700R4 / 6M
Axle/Gears: 89 IDK / 97 3.73
Re: timing chain question
How did you time it? If you timed the cam straight up and having clearance issues it's not going to help to advance/retard the cam. Most of those sprockets provide a 4 degree adv/retard. This will move the power curve around 500 rpm either way.
Old Nov 9, 2008 | 09:45 PM
leo037's Avatar
Axle/Gears: 323
Found the cause of the problem I knew as soon as I post I would find the cause. turned out to be I had it in the wrong mark. I need to pay better attention to detail and not rush things. Thanks for the fast reply
Old Nov 9, 2008 | 09:48 PM
Damon's Avatar
If the intake valve is hitting you want to retard the cam to help open up the clearance. Expect no miracles, however. If you have actual physical contact "straight up" ('O' keyway), retarding the cam by 4* (rectangle keyway) won't buy you enough clearance in a running engine. It'll still hit when you rev it up.
You need to go a little deeper into WHY you are having contact and fix it. Advancing or retarding the cam a few degrees is not how you fix a problem like this.
Old Nov 10, 2008 | 10:41 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
and I'm a professional automotive machinist. You should plan on some thicker head gaskets at a minimum. Fel Pro offers 'em, in MLS, in 0.062" and I seem to recall there's one even thicker. Yes, you lose quench, if you hafta vgo thick, but those heads need to come off anyway to double-check everything, before you bend all your intake valves.
Vintageracer
Jan 10, 2020 05:33 PM
ezobens
Aug 19, 2015 10:29 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
redmaroz
Aug 16, 2015 11:40 PM
