stripped torx bolt
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
stripped torx bolt
so im in the process of swapping my smog pump. one of the large torx bolts got stripped and it is now delaying my progress. i know this sounds stupid but i cant seem to get anything to work
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
Re: stripped torx bolt
I had a similar issue with a few of those torx bolts. what i ended up doing was taking the next size up torx bit i think its a t-50 and hammering it into the stripped bolt, basically making new grooves for the larger torx. i was able to get them out that way, and then i replaced them with standard bolts.
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
grind it off, quicker less painful, ended up doing this on my intake
Car: 1991 Chevrolet Camaro RS Red
Engine: 305 V8 TBI
Transmission: TH-700R4
i used vice grips on my torx bolts, you may have to take a file and file the sides down a little bit so the vice grips will get a good bite, or what we sometimes do at freightliner for the little buggers is take a cold chisel and cut in to the side in the direction that it would turn and beat it around loose untill we can turn it by hand. torx bits and allen heads do not belong on important stuff but i do believe that allen heads are tougher than torx.
UltRoadWarrior9
09-02-2015 08:24 PM
