Hesitation!!!!
Old Nov 11, 2008 | 05:06 PM
Gary Berg's Avatar
Car: 86 T/A WS6/Future project
Engine: 350 TPI/ Pontiac 455
Transmission: 700R4/TH400
Axle/Gears: Posi.
Hesitation!!!!
I have a 91 t/a 305 tpi when i start to excelerate the car feels like it wants to take off but it bogs. It just doesnt feel normal. The engine has 115 thousand miles on it. I put in new plugs, high flow oil, fuel pump and cold air intake on it and i still get the hesitation. Any ideas?
Old Nov 11, 2008 | 06:16 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Hesitation!!!!
Well, it could be several things, it's hard to say. Does it seem like it's starving for fuel or air? Do you get a check engine light? I would check timing first, make sure it's where it should be, and that the computer is advancing it as it should. It could also be a clogged cat, although that should cause power loss and hesitation across the board, not just off the line.
sidescrollin19's Avatar
Re: Hesitation!!!!
when do you mean? Right when you hit the gas or after it starts going?
Old Nov 11, 2008 | 07:05 PM
Gary Berg's Avatar
Axle/Gears: Posi.
Re: Hesitation!!!!
i dont the cat on, in pa if i keep it under 5000 a year they dont check for emissions. and it gets plenty of fuel and air. right when i hit the gas and in first and second gear it just bogs. o and no check engine light.
Old Nov 11, 2008 | 08:24 PM
Gary Berg's Avatar
Axle/Gears: Posi.
Re: Hesitation!!!!
Whats the timing for my car? do i need a lazer?
Old Nov 11, 2008 | 08:36 PM
Re: Hesitation!!!!
you driving a stick?? I jsut trying to think of simple things first obviously. I mean if youre just not hitting the gear at the right timing then that could be it completely. What mods are on the car?? If its setup really hot the lowend could be a little slower. Also define what youre talking about if your can. Bog down as it it doesn't react?? its just slow or what??
Old Nov 11, 2008 | 08:50 PM
Gary Berg's Avatar
Axle/Gears: Posi.
Re: Hesitation!!!!
no auto. the mods are high flow fuel pump, high flow oil pump, cold air intake and i put a buypass pipe in for the cat. it just doesnt react, when i hit the gas the rpms are fine but the car feels like its getting held back. is it cause i have high miles on the engine?
Old Nov 11, 2008 | 09:04 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Re: Hesitation!!!!
Still sounds like it could be a timing issue. Have you ever checked/set timing with a light?
Old Nov 11, 2008 | 09:08 PM
Re: Hesitation!!!!
ok well. Being high mileage there is a chance of things like a break pad partially stuck out and the car has to overcome it or something like that but its fairly unlikely.
personally after saying that id say its the fuel. Just as a lack of fuel hurts and engine too much of it is bad too. IF that high flow is setup is giving to much fuel it'll cause slow acceleration.
It could easily be the opposite too! hows your fuel filter?? being high mileage if its not replaced that could be bogging down your fuel and wasting the money you jsut spent on a new fuel pump!!! Check both those out.
Old Nov 11, 2008 | 09:09 PM
Gary Berg's Avatar
Axle/Gears: Posi.
Re: Hesitation!!!!
Never and im sure the owner previously hasent either. can i do it without a light? or would u recomend using one?
i did replace the fuel filter but its a cheap one would that matter considering the new pump?
Old Nov 11, 2008 | 09:20 PM
Re: Hesitation!!!!
A timing light shoots a strobe light aimed at your car's specific timing marks. The strobe flashes at the same time your #1 cylinder fires, which should mean that the timing mark (usually a line or notch on the flywheel) is lined up perfectly. If everything is timed correctly, you'll see a flashing notch down there. If not, you can adjust the timing until you do.
As for doing it without a light the only way I know is kinda by ear. You play with the dizzy until you get the smoothest,highest idle. And go rev the engine until you get the best response.
Old Nov 11, 2008 | 09:23 PM
Gary Berg's Avatar
Axle/Gears: Posi.
Re: Hesitation!!!!
ok ill see if the guy im rebuilding my other engine with has one i can use.
Fanatic1074
Oct 3, 2022 05:57 AM
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
