MAP Vacuum question
Old Nov 12, 2008 | 01:27 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
MAP Vacuum question
My 86 LG4 has a MAP attached to the firewall. Where does the vacuum line on the lower left of the MAP run to?
thanks
Old Nov 12, 2008 | 02:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Up close to the heater/AC box, right?
That's not a MAP sensor. That's a BAP sensor, barometric sensor. It's supposed to have a block of foam over the nipple as a filter, but no hose is attached to it.
The MAP is in the driver's rear corner of the engine compartment.
Old Nov 12, 2008 | 11:02 PM
Axle/Gears: Posi
Re: MAP Vacuum question
Thank you. I don't have the foam so is there something I can substitute or should I leave it alone?
91REDZ28VERT
Aug 18, 2015 10:16 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
squiggy2
Aug 9, 2015 09:30 PM
