Matching Cylinders at TDC?? (90 Degree method)
Old Nov 12, 2008 | 09:41 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I am doing a leakdown on a build while its on the stand and would like to know what the PAIR TDC cylinders are.
My valvetrain is not in yet (minus the valves and springs) so I just need to know what cylinders will be at TDC with eachother.
IIRC #1 and #4 are???
This is what I want to do...minus the whole firing bit.
Originally Posted by Apeiron
To make it easier on yourself, make 4 marks on your balancer at 0, 90, 180 and 270 degrees. Turn the engine over to TDC and look at the position of the distributor rotor. If it's pointing at the #1 terminal, then you're at #1 TDC firing, and the #1 valves are both closed. If it's pointing to the #6 terminal, then you're at #6 TDC firing, and the #6 valves are both closed. Then turn the engine over to the next mark on the balancer, and lash the next cylinder in the firing order. If you started with #1, it's 1-8-4-3-6-5-7-2. If you started with #6, it's 6-5-7-2-1-8-4-3. Continue until you've done all 8 cylinders.
Old Nov 12, 2008 | 10:27 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Matching Cylinders at TDC?? (90 Degree method)
1 8 4 3 6 5 7 2, pair them up:
1 8 4 3
6 5 7 2
1 & 6, 8 & 5, ...
Cylinders 1 8 4 3 fire on the first rotation, then 6 5 7 2 fire on the next rotation.
RBob.
Old Nov 12, 2008 | 11:02 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Thanks RBob. So to recap for myself and those searching:
At 0* 1 & 6 will be at TDC. 90* out will then have 5 & 8 at TDC, then 180* 4 & 7, and finally at 270* 2 & 3 will be at TDC.
Bubbajones_ya
Jul 6, 2024 08:32 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
