Looking for cam help 88 ioc z
Old Nov 15, 2008 | 03:16 PM
DROC-Z's Avatar
hey im looking to upgrade my cam i want a big heavy cam any suggestions i dont know anything about the specs. any suggestions on were to buy cheap alluminium heads thanks Derrek
Old Nov 15, 2008 | 03:47 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Re: Looking for cam help 88 ioc z
First things i would suggest buying heads first then getting a cam to compliment your heads. Buying a cam now on stock heads leaves you out to dry when you upgrade.
edelbrock has some cheap aluminum heads. they dont flow too well, but perform for the money.
Custom grind cams are really great too.
Old Mar 1, 2021 | 05:58 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I guess it's a good thing I was browsing in here as I noticed my name was mentioned. I did have a stupid fun 305 TBI back in the day that too be honest, I was just scratching the surface with that build. Here's what I did....
Mildly worked ZZ4 heads with a ZZ4 cam with 1.5 rockers on the intake and 1.6 rockers on the exhaust
port matched RPM intake with a trans-dapt plate and a ported stock TBI unit with an xtremefi adjustable regulator along with 55lb flow matched injectors. I was running the Hooker 2055 headers with an full 3 inch Aerochamber catback. All of this was tuned by the EBL FLASH using a Zeitronix ZT2 wideband run in open loop. It was a damn fun build that put the hurt on many cars. I plan on copying this again sometime later
maroon88iroc
Jul 19, 2005 01:04 PM
redcamaro83
Carburetors
17
Dec 1, 2004 06:08 PM
red rs
Jun 27, 2003 01:30 PM
92rsv8
Oct 5, 2002 07:01 PM
G92 IROC
Feb 7, 2002 09:22 AM
