driver side first spark plug filed out.....
Car: 1986 Iroc-Z28
Transmission: 4L60
Axle/Gears: 373
one day my car started running bad so i took it to some shade tree mechanic and he put some new plugs and he said my first plug on tha driver side filed out...he said it had oil in it.....he showed me the plug and it looked like way past due but it didnt have like oil dripping out or anything it had black stuff caked up a lil little....he said somthing bout the piston or somthing wall might be scatched a lil and letting a lil bit of oil seap in. what you guys think? he said his truck does the same thing and it wasnt that serious that when it starts running bad just change that one plug....when i got the car the guy said it runs rich, does that have anything to do with it filing out?
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: driver side first spark plug filed out.....
you can try putting come of that compression restore for 8cyl in it, i may help stop the fouling out of that one plug...
also it could be running rich for many reasons, like it needs a tune up (like plugs and wires, cap and rotor.....maybe a new coil sometimes ...... could be a O2 sensor also
Car: 1986 Iroc-Z28
Transmission: 4L60
Axle/Gears: 373
see i had the car for more than 9 months and its the 1st time its ever happen
Car: 77 K20 80 K2500 93 C2500 94 K1500
Engine: 350 350 454 350
Transmission: 350 465 80E 60E
Axle/Gears: 4.10 3.73 5.13 3.73
if its running ok now, i wouldnt really give it too much thought. pull it out in a few thousand miles and a have a look at it then.
Car: 1986 Iroc-Z28
Transmission: 4L60
Axle/Gears: 373
yeah its running like a champ. i will check it in a 1000 miles or so thankz man..
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
