Possible Bad Oil Pressure Gauge???
Old Nov 16, 2008 | 11:14 PM
The_Phoenix's Avatar
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Hows it going? Ever since I bought my '89 GTA last year, The oil pressure gauge needle pegs all the way the right when I put the key in the 'on' position as well as when its fired up. I had an engine rebuild a while back and the OPS was replaced with a brand new one so I don't think thats the cause. Looks like its a bad gauge then huh? Thanks in advance for any info.
Later,
Phoenix
Old Nov 19, 2008 | 02:21 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Re: Possible Bad Oil Pressure Gauge???
Later,
Phoenix
If the problem started immediately after the sending unit was replaced, then that is the problem. The replacement sending unit was intended for the idiot light, not the gauge. It's simply grounding out and causing the gauge to read full scale.
Easy fix is to procure and install the proper sending unit.
A bad gauge usually just doesn't operate at all.
Old Nov 19, 2008 | 03:43 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
I agree with Pete.
My gauge has been pegging the 60psi mark ..well since forever!
Ive yet to make the problem a priority, but it bothers me.. If the gauge
floats up to the peg line soon as you power the car (like my car) chances
are it is not the gauge like Pete said.
The connection has a ground issue or interference.
Ill get mine fixed eventually......
Old Nov 19, 2008 | 11:14 PM
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
This actually has been going on since I bought the car last year. I got a new unit put in already yet it still points to the far right.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
