Car cranks but will not start
Old Nov 17, 2008 | 03:04 PM
THETANK's Avatar
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
My 91 TBI will crank but will not turnover. It is getting fuel and right before this happened the car started to run very rough almost like one of the plug wires were disconnected ( they are all connected). The exhaust also had a raw fuel smell to it just prior to the car no longer starting. The last thing I noticed was I would have to push the accelerater to keep the car running while the above described symptoms were occuring ( eventually the car stalled and would not turnover again). Any ideas?
Old Nov 17, 2008 | 11:59 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: Car cranks but will not start
Are you getting spark during cranking????
Old Nov 18, 2008 | 06:05 PM
THETANK's Avatar
Car: 91 rs
I pulled one wire and it looks like it is getting spark ( not sure if that is the best way to check). I also have had a problem with the battery draining if i let the car sit for a few days at which time I have to hook it up to the charger.
bryan623
Mar 22, 2021 06:43 PM
TheExaminer
Aug 26, 2015 04:59 PM
mizz0313
Aug 12, 2015 06:45 AM
92projectcamaro
Aug 6, 2015 01:20 PM
