gas smell and a tick
Old Nov 19, 2008 | 08:28 PM
seannana's Avatar
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: Stock 3.42
i was driving and started to smell gas so i pulled over and pop the hood and i can smell it but cant find a leak. then it went away for a week or two. then i noticed a tapping sound developed. so i parked the car for a week. last time i took it out it still had the tapping noise AND the gas smell is back. i havent had a chance to really look at it. but is it possible that maybe an injector is going bad? could that be the clicking? and if its not working properly its just dumping fuel? any feedback would be appreciated
Old Nov 19, 2008 | 09:58 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: gas smell and a tick
Yes, it is possible. I had something very similar happen to me... I could smell gas but couldn't find it. Finally my motor hydro-locked and wouldn't roll over due to a cylinder full of fuel.
You can put the car on ramps, take out 1 spark plug at a time and then have someone bump the ignition. If fuel comes out of the spark plug hole - you found your bad injector.
Hope this helps!
Old Nov 20, 2008 | 07:01 AM
seannana's Avatar
Car: 1992 Z28
Engine: 5.7 TPI
thank you very much. i will give it a try asap. ill keep you updated
Old Nov 25, 2008 | 11:48 AM
seannana's Avatar
Car: 1992 Z28
Engine: 5.7 TPI
ok so i used a stethoscope and located the noise. it was inside the passenger side valve cover. i found a retainer clip and a couiple small pieces of metal. i havent been able to check it out during the day because by the time i get home from work its dark. but does anyone have any ideas on what to look for? im guessing it has to be either a lifter or a rocker?
Old Nov 25, 2008 | 07:00 PM
allenfre's Avatar
Hmmm.. Can you tell me what is the condition of your front side cover gaskets ? Do you ever consider a valve gasket replacement? I can't figure it out myself
Old Nov 25, 2008 | 09:09 PM
seannana's Avatar
Car: 1992 Z28
Engine: 5.7 TPI
they look good but i have new gaskets i will use when i get it back together. its tough to do anything on the street in the dark. i may have to send it to the shop if i cant get to it this weekend.
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
earlpote
Sep 12, 2015 11:55 AM
Glowsock
Sep 11, 2015 11:09 PM
