fuel preasure issues please read!!!!
Old Nov 19, 2008 | 10:12 PM
camarodubs's Avatar
Car: 1987 camaro
Engine: gm goodwrench crate 350 mild
Axle/Gears: 28 spline 7.625 10 bolt w/273
replaced gas tank with one with same setup, now when engine runs under demand it loses preasure. i have a holley carb on a computer operated carb setup, but it was runing ok before th tank swap. still using mech fuel pump. i took fuel line off before mech pump, when engine was cranking fuel flowed but when engine started fuel stoped, this system has an intank pickup that is electric, and the mech fuel pump. why does pickup work when engine is cranking and stop when engine stops. its like fuel seems blocked when engine is runing.
Old Nov 20, 2008 | 01:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sounds like something has happened to the running power to the in-tank electric.
specialized
Jun 18, 2022 09:26 AM
Wesly_66
Aug 26, 2015 09:55 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
djmarch
Aug 9, 2015 05:27 PM
