another hp estimate
Old Nov 20, 2008 | 12:48 AM
bmfIROC-Z's Avatar
another hp estimate
my buddy was wondering how many horsies hes got,he has a 350 bored 60 over,he says its balanced,10.5:1 compression pistons,world products cast iron 2.02int 1.60exh heads,weind dual plane intake,edelbrock 600cfm carb,.500int .500exh lift cam w/1.6 roller rockers,accel supercoil,plugs and wires and long tube headers w/raptor turbo mufflers,all this is in his 83 1/2 ton fullsize chevy pickup,so how much hp do you guys think hes pushin and what do you guys think he would run in the 1/4 with this setup?any estimates would be appreciated,thanks,joe
Old Nov 20, 2008 | 01:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Need more details on the cam (duration) and which dual plane Weiand intake. Crappy carb.
A full weight 1/2 ton pickup isn't going to be that fast. But, need details on gears, tires, transmission, stall, etc.
Old Nov 20, 2008 | 01:53 PM
bmfIROC-Z's Avatar
Re: another hp estimate
yeah i told him the carb was crappy,duration on the cam i think he said it was 284int and 284exh and the intake is the weiand p/n wnd-8004 action+plus intake,and the truck everything is stock with a stock 350 turbo,stock converter,15" street tires,not sure what gear he has ,whatever came stock with it.
Old Nov 20, 2008 | 01:56 PM
five7kid's Avatar
He'll be lucky to get into the 15's. It'll be a dog off the line with stock stall, and the carb will kill top end. Pretty poor combination of parts.
Old Nov 20, 2008 | 02:03 PM
bmfIROC-Z's Avatar
ok,so how bout a hp estimate? and it probably is a poor setup but he built the engine way before he got the truck and he just wanted something to put the engine in,so he baught the truck with a blown 305 and pulled the 305 and stuck the 350 in there,just wanted to know a rough estimate on the engine hp and 1/4 mile times.now that we know its got a crappy carb,a dog off the line and a poor combination of parts.
Old Nov 20, 2008 | 03:03 PM
five7kid's Avatar
World heads that have 2.02/1.60 valves are S/R Torquer and Sportsman II's , and can have 64cc, 67cc, 72cc, or 76cc chambers. "10.5:1 pistons" typically means with 64cc chambers. Some more details there would be helpful, too.
But, depending upon tune, it should have at least 320 HP, even if it isn't very usable.
Old Nov 21, 2008 | 11:27 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The heads are a good start, though not the best heads, they'll get him past 400 crank HP if he gets the rest of the combo to match.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
skip91
Sep 24, 2015 03:29 PM
ULTM8Z
Sep 16, 2015 09:15 AM
bellez77
Sep 5, 2015 08:39 PM
Trevor K
Jul 12, 2001 01:44 PM
