Cam question on 305
Old Nov 21, 2008 | 12:11 PM
lnsper's Avatar
Car: 92 RS
Axle/Gears: 3.27 4 wheel disc
Cam question on 305
I have a 92 RS that I am swapping the TBI to a TPI and I was thinking about installing a better cam Can the oil pan be lowered enough to get the timing chain cover off with the motor still in the car
Old Nov 21, 2008 | 12:23 PM
vette9190's Avatar
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
Re: Cam question on 305
yes it can, but if I were you(i was at one point put LT1 cam, and new edelbrock timing set in when I did my TPI swap), but I would pull the pan all the way out(have to lift the motor a little to get it out nd change the pan gasket at the sam time. I didn't do this and had/have a major oil leak lost 6 qts in under 1000 miles of driving. but since I'm swappin in a 350 over the winter it didn't really bother me to much.
Old Nov 21, 2008 | 12:42 PM
lnsper's Avatar
Car: 92 RS
Thanks for the help
Did you notice a big change with the cam?
I was thinking of not using a LT1 cam but something similar from competition products what do you think here is a link http://www.competitionproducts.com/p...?number=CS1079
Old Nov 21, 2008 | 02:12 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
I wouldn't trust a new roller cam at that price NEARLY as far as I could throw it! Besides, 0-4500 rpm???.....Come on, You're not gaining much with that one!
You'd be better off picking up a used LT1 cam for probably half that price.
As long as it was visibly OK, you'd at least know you have a quality part.
After all that work and expense, I sure wouldn't want to have a sub-quality cam material ruin my engine.
Old Nov 23, 2008 | 07:04 PM
vette9190's Avatar
Go with the lt1 cam. I wouldn't trust a
"new" 99 dollar cam.
I gave up a little low end but I can spin her right up to 5500 rpm and she pulls all the way. bc I lack the funds She will go into my 350 when I do the swap.
You should be able to find one on the boards here for around $30-45. I got mine here.
Old Dec 2, 2008 | 08:17 AM
86LG4Bird's Avatar
Insper, Would you be interested in a brand new Vortec/LT1-B cam pulled from my new GM Vortec longblock? Never been run.
$50 + shipping and it's yours. That cam makes excellent torque and pulls cleanly past 5000 rpm in a 350. It would pull higher in a 305.
Old Dec 2, 2008 | 09:30 AM
lnsper's Avatar
Car: 92 RS
Thanks 86LG4 for the offer but I think I am going to leav the stock cam for now
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
