Cant find needed intake/mod existing?
Old Dec 1, 2008 | 04:25 PM
skyhigh4by's Avatar
Car: 2004 GMC 2500HD
Engine: Duramax LLY
Transmission: Allison
There is no such intake for what I need..(Vortec/spreadbore/performer RPM.) What does exist is a (vortec/spreadbore/performer). Does anyone think that I could work the performer a bit to come a somewhat closer in performance to the RPM? Im using a comp cam 268 kit that has .479/.480 lift. I feel that the performer isnt going to have the flow in the higher rpms that I need. I would like to make power up to about 6000 RPM. Any suggestions??? Thanks
Old Dec 1, 2008 | 08:15 PM
Damon's Avatar
Re: Cant find needed intake/mod existing?
You're right- there's a hole in everyone's product line there. Irked me that they make a Performer RPM QJet intake (which works very well, by the way!) but no air-gap version and no Vortec version.
You're going to have to make do with the base model Performer Vortec Qjet intake and live with the upper RPM restriction. They're officially rated for idle-5500 but I've spun them up a little over 6000 and they still work decent- it's not like shutting off a light switch at 5500.
Old Dec 1, 2008 | 09:05 PM
toomany's Avatar
You could try to cut the center divider down a little bit. IIRC the RPM Air Gaps have a divider thats cut down some. I've also heard of people doing this to Performer RPM's with good results.
Old Dec 1, 2008 | 09:06 PM
skyhigh4by's Avatar
Engine: Duramax LLY
Well my cam specs say that it makes power from like 1500-5800 rpm, so I guess I wont be going to far out of the intakes range.
Old Dec 1, 2008 | 09:17 PM
skyhigh4by's Avatar
Engine: Duramax LLY
Do you mean the center section that makes it dual plane? To make it a little more like a single plane? Anyone else heard of this or have any pics or links on doing this?
EDIT: After looking at the AIR GAP style manifolds I see that the center of the plane is notched. Is that what is meant by cutting down the divider? What should I use to do it? Die grinder? I want to keep the surface inside the intake rough right? If I can get enough room under the hood this mod would probably go good with the use of a spacer?
Old Dec 1, 2008 | 11:16 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
too me, this seems like a good aplication for a carb spacer and an adapter plate. they do make a Q-jet to squarebore adapter right?
Old Dec 2, 2008 | 09:05 AM
kcb37's Avatar
You actually want the intake as smooth as possible.
That will let the air flow better. You probably won't feel a difference weather it is or not, so unless your a serious racer looking to make a few horses, it's not a problem.
Old Dec 2, 2008 | 09:58 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
There's always the option of getting your intake Extrude-Honed.
Old Dec 2, 2008 | 10:01 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not a good idea for a wet intake.
The difference between a Performer and Performer RPM isn't so much the flow capacity as it is the engine RPM tuning. Increasing the flow area of a Performer won't make it run like a Performer RPM. Cutting down the divider is a different question, and should be at least partially effective.
A Performer RPM with a spreadbore to squarebore adapter would be the simplest solution assuming adequate clearance for the air cleaner.
Frozer!!!
Jan 19, 2024 04:55 PM
IROCZ1989
Jan 24, 2016 03:55 PM
matthew911
Aug 12, 2015 09:38 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
