Head question
Old Nov 23, 2008 | 04:36 PM
TylerP's Avatar
Car: 89 T/A and 97 Formula (sunny days)
Engine: 305 TBI / LT1
Transmission: 700R4 / 6M
Axle/Gears: 89 IDK / 97 3.73
Head question
I plan on doing a little work on my TBI 305 in my 89 T/A and I was wondering if anyone knows what head castings are on this. I have found a set of 187's which I see came on a 305 HO,58cc chambers. I dont want to drop compression if the stock heads have smaller chambers. I plan on putting in some 1.94 intakes & 1.60 exhaust valves in the 187's along with a little port work. I also picked up some Edelbrock headers for $50 and I'm going to instal my LT1 cam I took out of my 97. I want to boost performance without hurting my mpg.
Old Nov 23, 2008 | 04:50 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Head question
187 are the stock TBI heads. The HO and TPI came with 416 or 081 castings, both of which are arguably better than the 187 castings.
Old Nov 23, 2008 | 08:19 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: Head question
I agree with Adam. Add 601's to the list of "better than 187" list. Any of those 3, in my opinion, are a much better platform for P&P work than 187's.
Old Nov 23, 2008 | 09:10 PM
TylerP's Avatar
Re: Head question
Hummm,the site I found the info might be incorrect then. I did find it odd that these heads I found came off of a 91 Caprice and they were HO heads. Anyway,I can get them for $25 for the set. With some bigger valves and port work they will still be better than what I am running. I just want alittle more hp and I'm not looking for a real fast car with the 89. Thats what I have my 97 for.
Old Nov 23, 2008 | 09:15 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Re: Head question
Pull a valve cover and get the casting number.
Old Nov 23, 2008 | 10:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That would be $25 poorly spent. I can't imagine what you could be running now that would be worse than those heads, unless they're 70's 350 truck heads with huge chambers and 1.72" intake valves.
Old Nov 24, 2008 | 12:12 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Head question
I've had the 350 version of the swirl-port heads on the flowbench, they don't respond to porting.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
