350 heads on 305 block?
Old Nov 23, 2008 | 10:26 AM
lee33lyn's Avatar
Car: 84 Z28
Transmission: 5speed
Axle/Gears: 3:23 posi disc brakes
Would there be any benefit to put a set of 71 350 heads on a 85' 305 215 hp block. I think the heads are 1:94 and 1:50.I'll have carb on the setup from the 84 305 that is in the car now.
Old Nov 23, 2008 | 11:39 AM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
Re: 350 heads on 305 block?
IMO, its not really worth it on a stock 305, the bigger chambers will lower your CR and the bigger valves wont do much on a tiny bore stock 305. You'd be better off having your heads ported, especially if there 416's.
Old Nov 23, 2008 | 02:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Guess what? Your 305 heads flow better than those old 350 heads, even with smaller valves.
Double down-grade - poorer flowing heads, lower compression.
The "right" thing to do would be larger valves in your 305 heads with some port clean-up work (yes, bigger valves will benefit, even with the small bore 305).
Old Nov 23, 2008 | 03:45 PM
lee33lyn's Avatar
Car: 84 Z28
thanks
Old Nov 23, 2008 | 05:03 PM
Car: '89 IROC-Z
Engine: LSx
five7 my machinest told me the 1.94's dont fit the 3.73 bore of a 305. Is this true? Because I would like to have my 416's cut for 1.94's.
Old Nov 23, 2008 | 08:42 PM
TylerP's Avatar
Car: 89 T/A and 97 Formula (sunny days)
Engine: 305 TBI / LT1
Transmission: 700R4 / 6M
Axle/Gears: 89 IDK / 97 3.73
I've seen 305 heads with 1.94 and 1.60 valves in them. Unless what I seen was not indeed a 305 head.
Old Nov 23, 2008 | 09:02 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
1.94's will fit.
Old Nov 23, 2008 | 10:17 PM
five7kid's Avatar
2.02's will fit the bore for mighty big lift #'s. Whether they're effective is a different question.
I had World Torquer 305 heads on my 305 (same ones on the 350 now), and they have 1.94" intake valves.
Old Nov 24, 2008 | 12:13 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
1.94s are good on 305s
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
mhatfield 14
Oct 24, 2015 07:48 AM
bamaboy0323
Aug 15, 2015 07:20 AM
BBSDesigns
Aug 11, 2015 07:39 PM
