350 swap start up
Old Nov 25, 2008 | 09:24 PM
dKillaCamaro's Avatar
Car: 83 Camaro
Engine: 5.0
Axle/Gears: 3.73 open
350 swap start up
any tips do's dont's on the first start up of my project its a used non rebuilt 350 under all stock lg4 components cc carb dist smog equp all that ''good stuff'' thanx for info
Old Nov 26, 2008 | 12:40 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Make sure it has oil and water. Check for leaks all around and under before and as soon as it starts. Set the timing as soon as you're done checking for leaks.
Old Nov 26, 2008 | 04:28 PM
Car: 83 Camaro
Engine: 5.0
Re: 350 swap start up
thanx quick question im putting a new oil pump on and not priming it till its all togeather then disable the dist and crank it till i get oil out the rockers would that be alright way of doing it
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
bellez77
Sep 5, 2015 08:39 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
