305ci Rear main seal
Old Nov 25, 2008 | 10:00 PM
83ChevC10's Avatar
Car: 83 Chevy C10 1/2 ton 2wd longbed
Engine: 305CID (5.0L)
Transmission: Turbo350
Ok, so im new to this forum but here goes!! I have an 83 chevy c10 with what i think to be a rear main seal leak. I would like to know if any one here has any experience with replacing this 2 part seal...;. thanx
Old Nov 26, 2008 | 01:17 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 305ci Rear main seal
Drop the pan, take the main cap off, fish the block half of the old seal out from behind the crank, push the new seal half in around the crank, replace the cap, replace the pan. Easier said than done, of course.
Old Nov 26, 2008 | 01:33 AM
83ChevC10's Avatar
do I have to remove the motor mount bolts and jack up the engine to get the pan out?
Old Nov 26, 2008 | 08:45 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No idea. This forum is for 82-92 Camaros and Firebirds only, not trucks.
xxx3man`
Sep 23, 2015 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
