Need help I.D.ing a Cam.......
Old Nov 27, 2008 | 07:58 PM
Beggins's Avatar
Car: 1987 Trans Am GTA
Engine: 355 TPI
Transmission: 700R-4
Axle/Gears: 10 bolt limited slip with 3.42
A friend of mine has a General Kinetics Cam the numbers on it are C1H-246-HT These numbers are on the front side of the cam along with the number 382. We are trying to find the specs on this to see if it going to work good for his 350.
Old Nov 27, 2008 | 08:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Need help I.D.ing a Cam.......
246 degrees advertised duration. It'll work but if it's used I wouldn't even bother.
Old Nov 27, 2008 | 10:43 PM
Beggins's Avatar
Engine: 355 TPI
it's a brand new cam. Anyone know the LSA and lift numbers on this cam???
Old Nov 28, 2008 | 01:20 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You can measure the lift.
sandman92084
Sep 12, 2015 10:27 PM
1992CamaroRS305
Nov 29, 2010 08:07 PM
dd85T/A
Jan 11, 2002 07:26 AM
