Summit starter & Hedman L T
Old Nov 28, 2008 | 09:32 AM
raptor80dad's Avatar
Car: 92rs
Transmission: 350
Axle/Gears: 3.73/Moser 12bolt
And a 168 tooth flywheel.Straight bolt pattern & 2 long bolts
I tried the solenoid aimed down and it hit the headers .I tried solenoid aimed up in top of the three holes and starter hits headers.I have notched the block to clear the headers and it will bolt up, but it sits right on the header.
Am I missing something here?Anyone got this to work?If not what brand are you using with long tubes?
The big stock one fit better,1" clearance,and overheated so I know this will not work.
thanks
Old Nov 28, 2008 | 09:53 AM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
Re: Summit starter & Hedman L T
You can get one of those wraps for the original style starter. I had the same overheating issue with my '73 Nova with long tube headers. Put one of those blanket wraps on it and haven't had any issues with it.
Now if they only made a wrap that could fix a blown turbo350 tranny......
Old Nov 28, 2008 | 10:37 AM
Car: 92rs
Transmission: 350
yeah that is what I did on the old motor, but upon searching came to the conclusion mini was the way to go.Looking at saving some weight and gaining clearance.
There is plenty of room between the block and the headers ,the bolt pattern on the starter just puts it too close to everything.
thanks for the reply
anymore suggestions?
Old Nov 28, 2008 | 01:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You could use the stock starter with a 153 tooth flywheel.
Old Nov 28, 2008 | 01:53 PM
Car: 92rs
Transmission: 350
Hope I don't have to go that route.
I think I can drill and tap new holes but 1 hole is right at the edge of the mounting block.Wish previous owner installed a 153 tooth
Old Dec 30, 2008 | 08:09 AM
Car: 92rs
Transmission: 350
Well I rotated the starter so it would fit ,drilled and tapped new holes installed starter yesterday and it fit perfect ,no shims at all.Pain in the butt but it is a perfect fit now.Just need to figure out this new wiring harness and try it out.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
school boy
Oct 22, 2015 11:47 AM
Zell1luk
Sep 29, 2015 10:36 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
