Need help with oil pickup replacement..
Old Nov 29, 2008 | 12:24 PM
CrimsonDragon's Avatar
Car: 89 IROC - 85 Z28
Engine: 350 / 305
Transmission: 700R4 / T5
Axle/Gears: Stock
Dented my oil pan and am replacing with a Milodon Oil pan - MIL 30702. I'm using the One piece gasket and Summit/Milodon are recommending the replacement of the oil pickup screen MIL-18600. It is calling for a press fit. Do I truly need to replace the oil pickup screen? and if so can I pull the oil pump when the motor is in the car to press in the oil pickup screen?
Thanks for the help.
Old Nov 29, 2008 | 12:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Need help with oil pickup replacement..
You don't need to replace it, but you should check the height of the pickup above the bottom of the pan. If you can get the oil pan off, you can easily take the oil pump off with the engine in the car.
Old Nov 30, 2008 | 12:53 AM
Engine: 350 / 305
Axle/Gears: Stock
Thanks for the reply. How do I check the height of the pickup?
Old Nov 30, 2008 | 08:05 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Modeling clay in the bottom of the pan where the pickup is located. Put it in there and then tighten up the pan. Pull the pan and check your distance that just got pressed into the clay.
Old Nov 30, 2008 | 02:47 PM
Engine: 350 / 305
Axle/Gears: Stock
Excellent advice. We greatly appreciate it.
gta892000
Aug 11, 2019 11:16 AM
djmarch
May 8, 2016 11:32 AM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
BDR
Nov 7, 2015 03:05 PM
