Vortec Plugs
Old Nov 29, 2008 | 11:34 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
Vortec Plugs
I have edelbrock E-tec heads (basically Vortecs) what are the best plugs for my application?
thanks
Old Nov 30, 2008 | 07:12 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: Vortec Plugs
Download and read the Edelbrock install instructions for your Etec heads.
The Etec heads do not use the same spak plug reach as a GM OEM Vortec head uses. Use a Champion RC12YC spark plug in the Etec heads.
Put some anti sieze grease on the threads. Do not try to remove the spark plugs unless the motor is cold.
OEM vortecs use a shorter .708" reach "RS" series spark plug. Not the same.
Old Nov 30, 2008 | 10:06 AM
avro206's Avatar
Car: 89 Formula
Re: Vortec Plugs
lol good diea--forgot I still have the printed instructions. It has some autolite plugs in now
Old Mar 16, 2009 | 09:49 PM
avro206's Avatar
Car: 89 Formula
Re: Vortec Plugs
okay I am not going with the champions--found an NKG bulliten here
http://www.ngkplugpro.ca/content/con...inderHeads.pdf
my question...what heat range do I get? I have 9:1cr
Old Mar 17, 2009 | 05:08 PM
F-BIRD'88's Avatar
Re: Vortec Plugs
There is just something about that tech bulliten that does not make any sense.
I suggest you start with the recomended Champions.
I've been using Champions for over 30 years without issues.
If you prefer not to use a champion, use a Autolite 3924 or AC delco FR3LS
gap at .035"
Old Mar 17, 2009 | 07:58 PM
avro206's Avatar
Car: 89 Formula
Re: Vortec Plugs
gap at .035"
doing a quick google search I see the that Champion plug is popular in lawn mowers!
It has autolites in right now but I don't know anything else about them. A tech guy at the track said they are junk.
I don't know
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
