mechanical fuel pump quest
Old Dec 2, 2008 | 01:16 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
ok guys im buying a new mechanical pump, 110gph holley brand, and it only has 2 connections. one inlet for fuel from tank, and one from the pump to carb. my quest is what one do i connect to the pump and which one do i cut and make it higher than tank for the venting? is it a vent or a return line?i wanna get it on the ball but i dunno which to do. thanks guys
Old Dec 2, 2008 | 01:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: mechanical fuel pump quest
The smaller line is a return, not a vent. It needs to be blocked if you're not using a return-style pump or regulator.
Old Dec 2, 2008 | 01:38 PM
Engine: 355
ok and wont have any issues blocking it?
Old Dec 2, 2008 | 01:47 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No
Old Dec 2, 2008 | 03:50 PM
Engine: 355
k thank u. since im running a bigger pump, do i need to run bigger fuel line? im gna be runnin a 100shot of nitrous to
Old Dec 2, 2008 | 05:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No.
Not sure why you went with that pump. I'm running a Carter M6626 ($29.39 on summitracing.com), rated at 120 gph. It has the return line, uses the stock 3/8" supply and 5/16" return lines.
The reason the factory used a return line was to reduce the tendency for vapor lock.
Old Dec 2, 2008 | 06:10 PM
Engine: 355
Originally Posted by five7kid
No.
thats awesome do u got the part number? id like to do that way better then blocking thank u man
Old Dec 2, 2008 | 06:39 PM
Engine: 355
i found the pump and ordered it. thank u. do i need a regulator for this pump?
Old Dec 2, 2008 | 08:24 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No
Old Dec 2, 2008 | 08:41 PM
Engine: 355
Originally Posted by Apeiron
No
U BEEN A REALLY BIG HELP!!!!!!!! THANK U. but one last question. y dont i need a regulator? will pump be ok running daily and with nitrous here and there? also it says up to 6.5psi max, dont i need more then that to run nitrous?
Old Dec 3, 2008 | 11:20 AM
Engine: 355
Old Dec 3, 2008 | 06:16 PM
five7kid's Avatar
Any fuel pumped that exceeds 6 psi to the carb is sent down the return line by the pump.
Old Dec 3, 2008 | 07:40 PM
Engine: 355
im still confused. then if it only pumps 6.5psi am i gna ruin my motor for not accomidating for the nitrous since u need 7psi or more?
Old Dec 3, 2008 | 09:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It would have been useful to know you were planning on using nitrous earlier.
Old Dec 3, 2008 | 10:01 PM
Engine: 355
take it i cant use that pump then? thought i posted it but must notta sorry.
No.
can that pump support 100 shot of nitrous?
Last edited by billybob6110; Dec 3, 2008 at 10:04 PM. Reason: Automerged Doublepost
Old Dec 4, 2008 | 12:10 PM
Engine: 355
i wanna go a different route and use an electric pump. can i just tap in by the tank and use that line to go directly to the regulator, and nitrous? totally bypass the mechanical pump and lines?
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
gta90
Sep 15, 2015 04:00 PM
justin57
Aug 20, 2015 07:05 PM
