altenator question
Old Dec 2, 2008 | 05:07 PM
mattyc's Avatar
Car: 1998 grand cherokee, 1988 iroc z
Engine: 350 tpi
Axle/Gears: ???
altenator question
I swapped out my alternator and I cant seem to see where this wire goes, its red
Old Dec 2, 2008 | 05:26 PM
rallysport383's Avatar
Car: 1989 camaro rs
Engine: 383 stroker
Transmission: t5
Axle/Gears: 4th gen/3.55
Re: altenator question
is this the wire going to the plastic connector? if it is, it should go to the 12volt distribution block by your battery
Old Dec 2, 2008 | 05:37 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It goes on the back of the alternator to the lug with a nut on it and plastic to isolate it from the alternator case.
Old Dec 2, 2008 | 05:51 PM
mattyc's Avatar
Engine: 350 tpi
Axle/Gears: ???
so I'll have the battery wire as well as this to the back of the alternator?
Old Dec 2, 2008 | 05:57 PM
Car: 1989 camaro rs
Engine: 383 stroker
Transmission: t5
this is a three wire altenator right?
if so, there should be a red heavy guage wire that goes from the threaded post on your altenator to the starter.
then there is two wires that come from the plastic connector on your altenator----the red one goes to the power distribution block next to your batttery and the other one, I believe it is tan, goes to the the ignition switch.
Old Dec 2, 2008 | 06:03 PM
mattyc's Avatar
Engine: 350 tpi
Axle/Gears: ???
this is a two wire.
Old Dec 2, 2008 | 06:17 PM
Car: 1989 camaro rs
Engine: 383 stroker
Transmission: t5
there is two wires that go to a plastic connector that plugs into the altenator, and a heavy guage wire that bolts to a post on the altenator right?
Old Jan 5, 2009 | 12:57 PM
mattyc's Avatar
Engine: 350 tpi
Axle/Gears: ???
yes, I have the heavy gauge wire hooked to the battery to the post on the back of the alternator. the plastic plug that plugs has two wires one goes towards the back if the engine, probably to the fuse box. the other wire is only a few inches long and not long enough to hook up to any thing.
and it has juice going through it
Old Jan 6, 2009 | 01:24 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
It goes to the same post as the battery wire like five7kid said.
I think it's the so-called sense wire, and the alt. has an internal low-ohms resistor from the sense terminal to the bat.+ post. for continued safe voltage regulation should the wire come loose. This makes it appear hot, though one shouldn't draw power from it while loose.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
