The Belt on the front of the engine??
Old Dec 4, 2008 | 02:09 PM
MYZ28NH's Avatar
Car: 91 Z28 Convertible
This belt just broke. I have another one and am ready to put it on. Can someone post a picture so I can see the pattern as to putting it on. Also what do you loosen in order to get the belt on and have proper tension? The alternator? Thanks Mike In the mean time I will keep searching for an engine compartment picture.
Old Dec 4, 2008 | 02:24 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: The Belt on the front of the engine??
Look toward the bottom of the following link:
http://sethirdgen.org/serpentine.htm
Put a breaker bar in the adjuster and push upward, as shown in the link.
JamesC
Old Dec 4, 2008 | 02:45 PM
MYZ28NH's Avatar
Thanks for the link. I got the pattern. Now what do you loosen to get the belt on? How do you know when you have proper tension? Just by the feel?
Old Dec 4, 2008 | 02:59 PM
MYZ28NH's Avatar
Got it on James...Thanks I owe you on. Mike
Old Dec 4, 2008 | 03:00 PM
JamesC's Avatar
Pull up on the tensioner (#1 in the diagram) to remove and install. The tensioner, as its name implies, automatically sets the correct tension.
JamesC
Old Dec 4, 2008 | 03:28 PM
MYZ28NH's Avatar
Car wouldn't turnover. Motor was vaper locked or something. It's like everything was to tight with the new belt to move. I put a socket on the big bolt on the alternater so as to move everything.. pistons an all. Went back into car and it started right up. All gages good again but the front end doesn't seem to like that belt... everything is noisy now. not squecking but just loud noise. Is this normal? Does the belt need to break in a bit to quiet down. The engine didn't sound like this before. I am going to take it for a quick spin ... see if anything breaks.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
