Temp sensor for EGR valve....where can you get them?
Car: 92 Formula 350
Transmission: TH700R4
Axle/Gears: 3.23 posi
Hi all
I have an issue. The temperature sensor with the wire that screws into the EGR valve on my car is pretty much done for. Rusty looking, and the inner piece that holds the wire is kinda busted and stuff just from being old or whatever.
That being said, online at Advance Auto Parts and whatnot, I cannot find the part. Just new EGR valves and gaskets. I cannot find anywhere that has this part, or they are websites that seem like they don't know the difference between a Firebird and a Thunderbird
Does anybody know where you might be able to get this part? Should I try stopping at a GM dealership?
I can get a picture probably if needed. Hopefully I won't need to go take one though because it's quite cold out up here lol
Thanks everyone!!
Thanks everyone!!
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: Temp sensor for EGR valve....where can you get them?
This should be the part your looking for. http://www.partsamerica.com/ProductD...pe=860&PTSet=A
