fuel system questions.
Old Dec 8, 2008 | 10:17 AM
whits87bird's Avatar
Car: 1987 Firebird
Engine: 305 LG4 lightly modified
I have a 1987 firebird with a 305 carb automatic trans. I have recently been having carb issues and decided to convert to fuel injection. I purchased holley's 2d projection throttle body injection to replace the carb. I had a shop look over the instructions so they could give me a cost. They called today and said that everything should work however I might have to get a new fuel tank because the one I had would not have the proper venting for a fuel injection. They also said if I call holley and ask them about using the evap canister fuel line as a return line. Holley said that was fine. Holley also said that they weren't sure why the shop was saying I would need a new tank. So my question is why they said I need a new tank thats vented for fuel injection.
Old Dec 8, 2008 | 12:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Gads, that's scary.
Right now you have a fuel supply, fuel return, and vapor recovery line going from the fuel tank to the engine compartment. The vapor recovery and supply line are pretty much a given to keep in place and use as currently. The return line depends, and I'm not all that familiar with that particular Holley set-up.
What's scary is if the shop says something like that, makes you wonder if they are competent to do this job.
Old Dec 10, 2008 | 04:39 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: fuel system questions.
You'll need a fuel pump that will supply the higher pressure required by the PRO-Jection TBI unit. The carb pump won't work for this application. You might have to replace the entire sending unit, but not the tank.
I assume you know this has an Emission Code 3-Amber therfore Not Legal For Street Use.
Old Dec 10, 2008 | 12:15 PM
Car: 1987 Firebird
thanks rgarcia63 the kit came with its own fuel pump, and in canada there isn't to much to worry about emissions wise. It was more of a miscommunication between me and the shop, its all been sorted out now thanks for the help guys.
MustangBeater20
Oct 29, 2022 09:20 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
69 Six Pack
Oct 5, 2015 07:51 PM
