LT1 intake on vortech heads?
Old Dec 9, 2008 | 01:51 AM
STEEL's Avatar
Car: 1991 Camaro RS
Engine: LO3
I know vortech heads need an intake designed to work with vortech heads, and I know vortech shares their design with LT1 heads, does this mean the Fuel injection system from the LT1 could be put on a Gen I small block that has vortech heads?
So if you have to machine an Lt1 intake to fit it onto a Gen I small block, and you have to machine tradisional intakes to fit on the Vortech heads, and the vortech heads are designed the same as LT1 heads, then if **** still rolls downhill, I could avoid all the machining by going with a newer EFI all together!
Does any one have any detailed information about this, or writeup from people that have done this?
Old Dec 9, 2008 | 06:10 AM
Damon's Avatar
Re: LT1 intake on vortech heads?
The LT1/LT4 heads and intakes have a unique bolt pattern all their own. It's not the same as Vortecs and it's not the same as earlier heads.
Old Dec 9, 2008 | 10:14 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
You would have bigger problems with the coolant and thermostat issues. Far easier to get a TPiS Mini-Ram.
Old Dec 9, 2008 | 08:58 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The LT1 intake bolt pattern is unique, but the the port layout is the same as a traditional SBC head, no the Vortec layout. They chambers were basically the same between LT1/Vortec heads, but the ports were diferent. As stated, the cooling system problems (no coolant crossover or T-stat housing) are more important swap problems with that intake. They also don't have a place for the distributor.
Best bet is a Stealth Ram... they even have a Vortec version now I believe.
LT1 intakes are cheap, because they only work on the Gen II engines (LT1/LT4/L99) unless you want to spend a ton modifying it.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
hayesaw0210
Aug 23, 2015 11:15 PM
theurge
Aug 21, 2015 12:46 PM
