oil pressure switch/sender question
Old Dec 9, 2008 | 01:13 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
ok so i just put longtubes on my car the other day and after installing them i put the oil switch/sender in. that was a pain the socket i bought didnt fit. anyways i got it tight, at least i thought so, with a 30 mm open ended wrench. well i go to start the car to see if i have exhaust leaks and notice that the sender is leaking. it drops about a drop every 5 seconds. when i had the motor put in, pre 86, they put my 91 sensor in the block so i can still use my gauge. it didnt leak before i put the headers in. does it matter that i put a 91 sensor in a pre 86 block? should i buy a different sensor. could it still be a little loose? how does everyone put theres in? like i said i couldnt slid the oil pressure socket over it because it hit the frame. what do you guys think?if i buy a wrench(1-3/16 i think) would that work better to install it? please help. i dont like dripping oil when i drive lol.
Old Dec 9, 2008 | 03:06 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: oil pressure switch/sender question
Obviously make sure it's tight, but try a little of the sensor-safe Loctite PST thread sealant (37615 is the one I use).
Old Dec 9, 2008 | 03:28 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Having the proper tools to do a job correctly always makes life so much easier
Old Dec 9, 2008 | 06:36 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
i had an oil sensor leak internally from the plug area is it leakin from the threads or the plug?
Old Dec 10, 2008 | 12:26 AM
the threads
well i did have the oil pressure sensor socket. i just couldnt slid it on because it was too close to the frame
Last edited by 91 camaro racer; Dec 10, 2008 at 12:27 AM. Reason: Automerged Doublepost
Old Dec 10, 2008 | 11:09 AM
tom86iroc's Avatar
Car: 1986 iroc
best bet u didnt get it tight enough
Old Dec 10, 2008 | 02:08 PM
yeah thats what i am thinking. how do you guys tighten yours? do you use a box end wrench? if so what size? i wish that socket would have fit.
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
