starting issues please help
Old Dec 9, 2008 | 03:37 PM
cityspud117's Avatar
Car: 91' z28
Engine: rebuilt 350
Transmission: stock
Axle/Gears: stock
i have a 91 z28. I have had loads of problems and thought i had it all fixed with my new 350 but i was wrong. The car will not start after it is all warmed up. For instance i was driving the other day and out of no where check engine comes on and the car shuts down...i pull over and it just cranks and cranks and cranks but will not start, it will only start if i let it sit for a few hours. Just recently i had replaced starter, battery, and spark plugs ,and map sensor. Any help would be awsome thanks in advance.
Mike
Old Dec 9, 2008 | 03:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Retrieve the trouble code(s) from the computer. If the check engine light came on, there should be a code unless it just came on because the engine died.
Sounds like a weak electrical component, though, like the ignition module or coil.
Old Dec 9, 2008 | 03:54 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: starting issues please help
x2 on the ignition module - I had one that would work fine when cold, but would start acting up when it got hot. If you can, let it run and warm up in your driveway until it dies, then see if it's getting spark while cranking.
Old Dec 9, 2008 | 03:56 PM
Car: 91' z28
Engine: rebuilt 350
Transmission: stock
Axle/Gears: stock
yeah i forgot to mention that the CE light only came on because the car died. Do you think it could be fuel pressure related, because also when the car first starts up when its cold whether i put it in drive or reverse, it jumps as in the tach but soon as it is warmed up its smooth until i turn it off and cant turn it back on.
thanks for the input ill give that a shot.
Last edited by cityspud117; Dec 9, 2008 at 03:57 PM. Reason: Automerged Doublepost
Old Dec 11, 2008 | 03:43 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
It could be fuel related, but I'd still lean towards something electrical. The fuel pump temperature doesn't really change very much from cold start to operating temp. It's easy enough to test though, buy or rent a fuel pressure gauge and check it at the fuel rail.
Also, the hard kick into gears when cold could be normal. When the engine is warming up, the ECM makes it idle faster, around 1000RPM. When it's warmed up, it should idle around 800RPM. This would explain why putting it in gear when cold makes the car jump more.
Autozone can test an ignition module, and it's not too hard to remove. Pull the distributor cap off, and it's the little module bolted to the distrubutor base.
Old Dec 11, 2008 | 03:58 PM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
Not sure I completely understood your comment about the tach above. If the tach needle jumps around without the RPM of the engine changing then you might have a pickup coil issue.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
